disable pim ssm tunnel
disable pim {ipv4} ssm tunnel [tunnel_name | tunnel all]
Description
Disables PIM SSM tunnels on a router interface.
Syntax Description
ipv4 Specifies the IPv4 address family.
ssm Specifies PIM SSM mode.
tunnel Specifies the tunnel name.
tunnel_name Specifies to configure PIM information for interfaces.
all Specifies to configure PIM information on all Layer 3 interfaces.
Default
Disabled on all interfaces.
Usage Guidelines
This command disables PIM-SSM on the specified Layer 3 VLAN.
IGMPv3 include messages for multicast addresses in the SSM range is only processed by PIM if PIM-SSM is enabled on the interface. Any non-IGMPv3 messages in the SSM range are not processed by PIM on any switch interface, whether SSM is enabled or not.
The following example disables PIM-SSM multicast routing on tunnel accounting:
disable pim ssm tunnel accounting
This command was first available in ExtremeXOS 32.3.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
